need help
lolas
PostPosted: Sun Apr 13, 2008 1:29 pm    Post subject: need help Reply with quote
hi,i have a 1gb 2,8 touchscreen player when i want to play video it shows only white stripes and also when i want to upgrade firmware program says that no usb device detected any thoughts?
PostPosted: Mon Apr 14, 2008 7:25 am    Post subject: Touchscreen MP4 Player Will Not Play Videos... Reply with quote
Do you have any idea of the manufacturer, make, model of this MP4 player?
Are there any board ID numbers that you may have? Also, do you have any pics that you may share with us, to give us an idea what type of MP4 Player this may be (if it's a generic MP4 player)?
What firmware file are you trying to upgrade the player with?
Did you make sure that you backed up the original firmware of the MP4 player, before attempting to upgrade it?
The more detailed information that you provide, then the more likelihood that you will get an accurate and correct diagnosis and resolution to your problem.
lolas
PostPosted: Mon Apr 14, 2008 11:17 am    Post subject: Reply with quote
problem solved Rockchip only support its native resoliution ,viDrop program worked like charm on this.
PostPosted: Thu Apr 17, 2008 11:35 pm    Post subject: Reply with quote
Thanks for that update lolas. That is good to know.
How did you figure that out?
