Help! Dead player + Unrecognized by Windows
Post new topic   Reply to topic    MP4 Player Users Forum Index -> MP4 Player Firmware Upgrades/Updates
Samir88
PostPosted: Sat Feb 27, 2010 1:22 pm    Post subject: Help! Dead player + Unrecognized by Windows Reply with quote
[b]Hi everyone;[/b]
I had a small problem with my mp4 player. I upgraded it then but using another version: 9.1.52 ==> [b]The result:[/b] dead player Exclamation.
I upgraded it again using the version 9.1.51 ==> [b]The new result:[/b] dead player + unrecognized by windows Shocked (nothing happens when I connect the device to the PC).
[b][u]Here are my MP4 player's features:[/u][/b]
[b]- Firmware:[/b] 2006/03/13 - 9.1.51 - ACU7515_s75 - 2006/12/07
[b]- Title:[/b] MATRIX FPC-TGS000190AC02-00 Ver0.1 - SAMSUNG 716 K9G8G08U0M PCB0
[b]- Plate N°:[/b] BO-050
[b]- Screen Size:[/b] 2"
[b]- Memory Size:[/b] 1GB
[b]- Others:[/b] Mini SD slot - Speaker - FM Radio - Sound Recorder - 1 Game (tetrix) - Mp3 player - Movie player - Picture Viewer - Text Viewer
How can I make it recognized again by my PC Question
And please I need the firmware.
[b]Thanks in advance.[/b] Smile
PostPosted: Sun Feb 28, 2010 7:21 am    Post subject: Reply with quote
Always backup the original firmware on your mp4 player, then update with same firmware version for your mp4 player otherwise you will 'brick' your mp4 player.
How long have you had the player? If you have a problem with it and you purchased it within 30 days you can return it for refund or replacement. Try and talk to the seller and see what they say about replacing the player.
Make sure you have the correct firmware for your mp4 player and then try again to update it and see what happens. You can do a search in this forum about the steps needed to update your mp4 player's firmware.
Samir88
PostPosted: Sun Feb 28, 2010 2:40 pm    Post subject: Reply with quote
Thank you MP4Guru for your reply.
[quote]Always backup the original firmware on your mp4 player, then update with same firmware version for your mp4 player otherwise you will 'brick' your mp4 player.[/quote]
Yes in fact I already upgraded my mp4 player with a wrong firmware Confused .. Now I haven't its original firmware but here are the features:
[quote]How long have you had the player? If you have a problem with it and you purchased it within 30 days you can return it for refund or replacement. Try and talk to the seller and see what they say about replacing the player.[/quote]
Unfortunatelty I purchased it long time ago and I can't talk to the seller about its replacing.
[quote]Make sure you have the correct firmware for your mp4 player and then try again to update it and see what happens. You can do a search in this forum about the steps needed to update your mp4 player's firmware.[/quote]
The problem is that windows doesn't even recognize the device (nothing happens when I connect the device to the PC). And the MP4 tool can't upgrade it again as long as it is not recognized by windows.
How can I solve this problem?
Thank you again.[/quote]
PostPosted: Mon Mar 01, 2010 7:22 am    Post subject: Reply with quote
You say that your windows PC does not recognize the mp4 player. What version of Windows are you running? XP? 2000? Vista? 7?
Have you tried connected the mp4 player to another computer with a different version of Windows running? (Sometimes some computers may have bad usb ports, so testing on another pc will eliminate or confirm problem).
Samir88
PostPosted: Mon Mar 01, 2010 3:39 pm    Post subject: Reply with quote
[quote="MP4Guru"]You say that your windows PC does not recognize the mp4 player. What version of Windows are you running? XP? 2000? Vista? 7?
Have you tried connected the mp4 player to another computer with a different version of Windows running? (Sometimes some computers may have bad usb ports, so testing on another pc will eliminate or confirm problem).[/quote]
I am using Windows XP SP2. I tried to connect the mp4 player to other computers but nothing happened. I changed the cable and nothing new! This problem started just after the second upgrade of my mp4 player Sad
PostPosted: Tue Mar 02, 2010 6:08 am    Post subject: Reply with quote
@Samir88, check this link below for troubleshooting steps to have your PC recognize your mp4 player:
[url=http://etronicsland.com/page.html?chapter=0&id=31]Steps to troubleshoot mp4 player to PC connection[/url]
xw227751
PostPosted: Thu Mar 03, 2011 10:05 pm    Post subject: PDF to Image Converter----Your Best PDF to Image Converter Reply with quote
PDF to IMAGE Converter wanted to own!!!
[url=http://www.pdftoimageconverter.com]PDF to IMAGE Converter[/url] with reliable quality and humanized design is your ideal helper, which can protect U from having troubles in converting pdf to image! Unimaginable functions will not let U down forever!
Powerful evidence: using PDF to IMAGE Converter, U can convert pdf to all kinds of image formats: JPEG, PNG, GIF, BMP, PCX, TGA, TIFF. U can also adjust the color, quailty, resolution, page of the files converted!
[img]http://www.pdftoimageconverter.com/images/pdf-to-image-converter.gif[/img]
This screen of PDF to Image Converter has showed its great advantage. As soon as lauching PDF to Image Converter, you will find it is so useful!
Helpful steps of converting PDF to Image:
You need to downlowd and install PDF to Image Converter on your computer!
You can add or delete your files and folder by cicking these buttons:
[img]http://www.pdftoimageconverter.com/images/convert-pdf-to-image.gif[/img], you can also click the "File" button to finish these steps.
Then you can adjust your files by settting the following regions,
[img]http://www.pdftoimageconverter.com/images/how-to-convert-pdf-to-image.gif[/img]
If U are satisfied with the results above by previewing, you can click the "Convert" button to convert PDF to Image! Remember to set destination folder by clicking the "Browse" button.
[img]http://www.pdftoimageconverter.com/images/converting-pdf-to-image.gif[/img]
All steps are finished, I think that PDF to Image Converter has dealed with your problems! So, you have owned best assisstant! Congratulation!
Other useful tools, please attention :
[url=http://www.pdftoimageconverter.com/pdf-to-gif-converter.html]PDF to GIF Converter[/url]
[url=http://www.pdftoimageconverter.com/pdf-to-jpeg-converter.html]PDF to JPEG Converter[/url]
[url=http://www.pdftoimageconverter.com/pdf-to-tiff-converter.html]PDF to TIFF Converter[/url]
[url=http://www.pdftoimageconverter.com/pdf-to-bmp-converter.html]PDF to BMP Converter[/url]
[url=http://www.convertm2ts.biz]convert m2ts[/url]
[url=http://www.convertm2ts.biz/convert-m2ts-to-mkv.htm]convert m2ts to mkv[/url]
[url=http://www.convertm2ts.biz/convert-m2ts-to-wmv.htm]convert m2ts to wmv[/url]
[url=http://www.convertm2ts.biz/convert-m2ts-to-avi.htm]convert m2ts to avi[/url]
[url=http://www.convertm2ts.biz/convert-m2ts-to-flv.htm]convert m2ts to flv[/url]
[url=http://www.convertm2ts.biz/convert-m2ts-to-mp4.htm]convert m2ts to mp4[/url]
[url=http://www.convertm2ts.biz/convert-m2ts-to-mpg.htm]convert m2ts to mpg[/url]
[url=http://www.convertm2ts.biz/convert-m2ts-to-mpeg.htm]convert m2ts to mpeg[/url]
[url=http://www.convertm2ts.biz/convert-m2ts-to-mov.htm]convert m2ts to mov[/url]
[url=http://www.convertm2ts.biz/convert-m2ts-to-vob.htm]convert m2ts to vob[/url]
[url=http://www.convertm2ts.biz/convert-m2ts-to-dvd.htm]convert m2ts to dvd[/url]
[url=http://www.convertm2ts.biz/convert-m2ts-to-ipod.htm]convert m2ts to ipod[/url]
[url=http://www.convertm2ts.biz/convert-m2ts-to-iphone.htm]convert m2ts to iphone[/url]
[url=http://www.convertm2ts.biz/convert-m2ts-to-psp.htm]convert m2ts to psp[/url]
[url=http://www.convertm2ts.biz/convert-m2ts-to-xbox.htm]convert m2ts to xbox[/url]
[url=http://www.convertm2ts.biz/convert-m2ts-to-avchd.htm]convert m2ts to avchd[/url]
[url=http://www.convertm2ts.biz/edit-m2ts-files.htm]edit m2ts[/url]
[url=http://www.convertflv.biz]convert flv files[/url]
[url=http://www.converttom4r.biz]convert to m4r[/url]
Post new topic   Reply to topic    MP4 Player Users Forum Index -> MP4 Player Firmware Upgrades/Updates All times are GMT - 4 Hours
