8GB 2.8in touch screen MP4 player stopped working
NastyT23
PostPosted: Sat Apr 25, 2009 3:19 pm    Post subject: 8GB 2.8in touch screen MP4 player stopped working Reply with quote
I have an 8gb touch screen mp3/mp4 player bought off of ebay and it was working fine up until a few days ago. All of a sudden it just stopped working. when i plug it into my cpu the cpu doesn't even recognize it anymore. When i turn it on it stays frozen at the welcome screen and i have to press the reset button to shut it off...Is there any way i can get it to work again?
NastyT23
PostPosted: Sun Apr 26, 2009 11:53 am    Post subject: Reply with quote
I've taken apart the mp4 player and got the numbers on the circuit board which are:
TY_606V01
and there were a second set of numbers which im guessing is the build date:
2008.4.14
The memory chip is a SAMSUNG 837
Thanks for any help.
jingwen
PostPosted: Mon May 11, 2009 10:55 pm    Post subject: Reply with quote
If the cpu could not recognise your player,you should change data wire,and if your player also could not use,i think you need ask the saler.
Spikestrip
PostPosted: Fri May 21, 2010 1:36 am    Post subject: Same problem - player is #5 in the graphic above Reply with quote
Same issue~ I formatted my player (fifth player in graphic at the top of this page), now stuck at welcome screen, and the PC does not recognize the player. Any thoughts?
TIA!
PostPosted: Sat May 22, 2010 4:21 am    Post subject: Reply with quote
@Spikestrip, you can try another usb cable and try connecting your mp4 player to the pc and see if it gets detected.
As for the 'welcome screen' problem, it could be a firmware issue.
